I have a 2001 tige 20i with a 350 mecrusier motor. The motor starts fine when unloading but the problems begin after the boat has been running for awhile. if it sits still for more than 10 minutes it wants to act
like it has run out of gas. it will start but slowly dies due to the lack of fuel. The only way i found to get it running again is to remove the fuel line from the fuel filter and let it drain for a couple of seconds,then reconnect it. After doing this it runs fine but i dare not cut the motor off
cause if you do it happens again....I have replaced the fuel pump,(3 times), cleaned out the gas tank. Replaced the fuel line and fuel filter.
I also removed the check valve in the gas tank but no luck......
Is anyone else having these problems???? any cures???
Note: This motor is fuel injected....
