Well we were out this weekend had a great time. We started back into the ramp when I noticed the taps stopped working. So I played with it a bit and got to go back up and the could get it to work again
So I dig into it tonight notice the fluid was very low. So I thought that was it. Nope. So I get under the dash and I can hear it click when push the button. So I clip all the tie raps and find a nine wire relay of some sort of relay has with blade connectors so I undo all of them and reconnect. I try and it starts to work, so I thinking great no problem easy fix. I raise it up and down a couple time then and let go of the button wait a sec then try again nothing just the click sound out of the relay. So I give it 3-4 mins try again and it works. I try the same step and it stops working about the same time.
So here is my question is it like heat protected so you can't run in up and down a lot not that you do that on the lake since I'm testing I would like to with out it stop working. But I know I have never had an issue with it not working on the lake before.
Any help would be great.
Thanks
Sam
Thanks
Sam
