I was out looking at my trailer and decided to look at the oil level. Trailer brakes didn't seem to be working. I take of the cap to look at oil level, it appears to be fine then I start looking closer and what do I see rust on the in side of the master cyclinder .
So I stick my finger in and it appears to be water, It has a fail dot 3 smell and not very oily to the touch. So then I move to the wheel to take a look, so I take the tire off to find the the hub is a bit loose . At this point I about to scream.
1. How do I rectify the brake fluid/water issue. I tried pushing the acutater and I see nothing moving. So any thoughts.
2. I want to redo the wheel bearing how to find out what you need??
Thanks
Sam
Thanks
Sam
