Originally posted by vr6wannabe
View Post
Marine Power Impeller
This is a sticky topic.
A new one I just learned this weekend involving the impeller... After you take the plate off of the water pump to check the impeller, take the impeller out, even if it appears to be completely intact. Once out, double check to make sure that the rubber part of the impeller doesn't spin on the brass "spline." I had mine do it this weekend, at low speeds, no problem but under load the impeller was slipping around the water pump drive shaft. Sooo lesson learned for me was make sure to have tons of the proper type of lube when you put it together, and possibly lube it up every season whilst de-winterizing.
Originally posted by Matt Garcia View PostDoes anyone know what kind of impeller that Marine Power engines use? Is it the same as what Mercruisers use? I have the Marine Power HT 360HP engine.
Also does anyone have an idea on where the impeller housing is located? I am taking my boat on a small vacation and wanted to be prepared in case anything happens.
Thanks
thanks for sharing this thread. the Alco Spares is the most important spare part in marine power supplier.
Originally posted by indogerman77 View Postthanks for sharing this thread. the Alco Spares is the most important spare part in marine power supplier.Oh Yeah!
Nice information sharing and its very useful tips indogerman industries prvide locomotive rebuild and honey chrome process
