Noticed my swim platform brackets were slightly loose. Pulled them off, and bought new nylon lock nuts. Problem is that the thru holes in the boat are much larger than rhe bolts. Holes around bolts were filled just about evenly with marine sealant. Is this normal, how it should be? Or should i go look for some kind of bushings? I tried to reach out to tige, but im sure they are buried right now and not sure if I will get an answer back before I have to get this done tonight so i can give the boatlife 36 hours to cure before dropping the boat on Saturday. Please let me know thoughts. Thanks everyone!
