A have a 2001 21V . . . lately, when I press the TAPS switch, the system seems to draw too much battery voltage . . . it causes the WAKEBOARD PRO gauge to shut down . . . I checked the plate to see if it is moving and also disconnected it from the plungers and it moves freely. The reservoir is 2/3 full and there are no leaks that I can see. The motor is working but seems to be working very hard . . . any thoughts on what I can test or look at??? Thanks, Steve
TAPS System Issues
Re: Re: TAPS System Issues
Originally posted by lee
Try the new RZ2 at your local dealer!
To answer the question, it sounds like there's either something in your hydraulic lines or the pump itself is starting to go.Last edited by dogbert; 11-14-2006, 12:37 PM.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
