Hey guys, I have a new to me 08 Z1 with the taps 2. The gauge is stuck at 8, the actuator does run up and down. So I assumed the actuator was bad and called Bennett which told me how to test it. When I went to test the sensor I found that there is no wires coming out of the actuator. Upon further investigation, I found the wires under the dash have been cut off and there is no wires at all going to the back except the pump wires. I am assuming someone swapped the actuator at one time with a non-sensored one for what ever reason. Does anybody know the correct part # for it? Bennett needs the original part # to cross it to the new actuators. I have contacted 4 different dealerships to get prices on a few other parts and only heard back from 1 after 2 weeks. Even contacted Tige direct and talked with tech support, he was going to get with parts and get back to me and never has, i have called back several times and leave messages, but no return calls. Frustrated with Tige customer service at this point. Any help here would be greatly appreciated.
taps 2 actuator part #
Originally posted by tigemt View PostHey guys, I have a new to me 08 Z1 with the taps 2. The gauge is stuck at 8, the actuator does run up and down. So I assumed the actuator was bad and called Bennett which told me how to test it. When I went to test the sensor I found that there is no wires coming out of the actuator. Upon further investigation, I found the wires under the dash have been cut off and there is no wires at all going to the back except the pump wires. I am assuming someone swapped the actuator at one time with a non-sensored one for what ever reason. Does anybody know the correct part # for it? Bennett needs the original part # to cross it to the new actuators. I have contacted 4 different dealerships to get prices on a few other parts and only heard back from 1 after 2 weeks. Even contacted Tige direct and talked with tech support, he was going to get with parts and get back to me and never has, i have called back several times and leave messages, but no return calls. Frustrated with Tige customer service at this point. Any help here would be greatly appreciated.
Sent from my SM-G960W using Tapatalk2008 Tige Z1 Limited Ronix Edition
360 hp, Fly High ballast, Alpine, JL Audio, Kicker, Wetsounds audio
