Hello All,
Boat was running great yesterday. I went to start the engine and nothing happened. I jiggled the gear shift a few times and it started and ran fine. Later that day it did the same thing again so I messed with the gear shift again and it started. It took several attempts and I was concerned it was not going to start. Now I'm worried about taking it out again until i find the problem. I suspect it is the neutral safety switch that keeps the engine from starting if the boat is in gear. Can someone direct me to the location of that switch and possibly any additional items I should check that may cause this issue? Thank you. Doug
