So many variables... and you said you exhausted all prop options so i won’t even rehash that.
You want a blower and that’s awesome. The extra power is
Amazing , however. Sometimes you can get the hull beyond what any power will fix which is what mike and I subsequently have been trying to say. That power is only as good as the wheel you are going to use to efficiently transfer that said power to the water.
If the boat won’t plane with a crazy prop, then to me you have one of two issues.
1. The boat is incorrectly weighted
2 The Motor is hurt
My concern with your situation is that it seems like you are far off on one side of the equation.
Will the said blower Hp fix it? I don’t know but it seems like from what you are describing that we are talking about a big margin to overcome.
Yes the blower is nice... but let me tell you have had every current indmar package and trans.
When you stick weight too then especially the amount of weight you are using which inhibits the boar from planning correctly... their isn’t a blower out that will fix it.
2 The Motor is hurt
