I have a 2002 Tige 20v Mercruiser. Today I took the boat out for the first time in 2 months and the battery was fairly low. I tried to to start the engine 10-12 times at the launch, before pulling up and re-charging the battery. After I did that It still wouldnt start, and appeared that I had flooded the engine. I used the throttle and key simultaneously to get it started.
Once we were out on the water the boat seemed to lose power, or even die 1 or 2 times when I would give it throttle quickly. If I slowly did this the rpms would remain constant. Towards the end of the day the boat went well.
Seems as though I have a fuel issue. Ideas? Did I flood it at the launch and that caused the day of issues? Do I need a new fuel pump?
Thanks!
Chris
Thanks!
Chris
