Took the boat out last night, the first time it fired up fine but the last split second make a grind/whine noise as the engine fired up. We cruised around for a while then anchored to swim. About 1.5 hours later the boat would not start - it just produced a grinding / whine noise which I think indicates the bendix isn't engaging the flywheel. The noise continued for 2-3 seconds even after I stopped turning the key, so I think it kind of stays stuck in the up position even after voltage is removed from the coil. The batteries are good and fully charged.
Does this sound like a bad starter? If so - is the ARCO 30459 the correct part? Thanks.
