I bought a 1998 2100v and when idling the transmission oil pressure warning light comes on but then goes off as speed increases. It will stay off for a few minutes after returning to idle speed but then come back on. Which transmission is this warning light for, the v-drive or transmission? Is this a common problem or something I need to be concerned about. Someone told me that as long as it goes off when not idling that I should not worry about it? Does anyone have a manual for the 1998 2100v that I could copy?
Oil Pressure Waring Light / Alarm
Thanks jimidemo, I checked all fluid levels and compression and they all look good, just working on getting a few gauges & warning lights operational. I have ordered a new tach which I hope is the problem, visible water damage inside but I am also having trouble with TAPS gauge, wiring was not connected, I had to replace pump, so now it moves correctly but gauge does not work.
