Does anyone know a part # for the fuel check valve on the gas line coming out of the tank to the fuel pump? This is for a 05 24v with MP 5.7 340 hp. I am doing some preventative maintenance.
I have the 05 22v with the same engine and I didn't notice any check valve in line to the low pressure fuel pump. I am planning on installing an inline fuel filter this winter though.
Yep, I am planning to do the same with an inline filter between the tank and LP fuel pump. I have seen that some LP fuel pumps have a screen on the inside barb that gets clogged that can cause fuel starve engine issues.
