TAPS pump res on 2002 2300V?
    Can anyone point me in the direction where the pump reservoir would be for the TAPS system on a 2002 23V?
    In my 2001 I believe it's behind the small access panel in the back (stern) side of the starboard locker. You have to remove two thumb screws to take the panel off & access the pump & reservoir.
      I think that is the same panel out extra battery is in. I will check it out. Thanks!
