Throttle Question
    Throttle Question
    Just launched my Tige after a long winter storage....the throttle, upon last season, went from 12 o"clock to 9 O'clock max. I noticed on its first ride that the throttle now goes to around the 7 O'clock position? Is there an adjustment that needs to be addressed? The boat was winterized serviced last fall. No other work has been done.
    TIA,
    Check for anything in the way at the back of the throttle.
    Sent from my HTC 10 using Tapatalk
      If you have PP or Ridesteady, and you do not have power to the motor that winds the rope to pull the throttle linkage, you will get this sort of thing. I found that out after installing Ridesteady and forgetting to turn it on. Should have wired it right to the ignition switch so I wouldn't have to worry about it.
        No PP or Ridesteady. I'll check the linkage later today.
        Thanks for the replies.
