Hi
My TIGE 20 V year 2005 with engine MP 340 HP , is now only used in saltwater . So I want to build a full cooling system , if possibly with the use of plate heatexchanger.
( as I can get them cheap - in stainless steel version ) - but which size ?
When I look at the manifold ,first section has two plugs - but upper only one ? . So when I block off - shall i use both lower connections ?
Can I reuse termostathousing - by blocking off most off the connections ?
Which size termostat , and does the temp alarm need to be reprogrammed ?
Best regards
Søren Damm , Denmark
Best regards
