I have a 2008 z1 with a 5.7 vortec, my voltage gauge is only reading 12.1 when the boat is running. I had the alternator off and checked and it is putting out 14.1 - 14.3 so that is good, my readings coming out of the isolator switch is just over 12 on each side (each battery). Does anyone know anything about the isolator switches, do they go bad, how many volts should I be getting coming out of the switch. I have a two battery system with an on/off switch. It is a Charles industries isolator switch.
