Tige 20V - Walter Drive
    Hi
    Did today try to check oil level at my new old boat . ( 20V year 2005) . But when i tried to pull the oil dip stick , it was broke and stock in the housing. Did then remove top from Water/oil cooler - and still here it is stock due to corrosion ( boat has only been used in saltwater) . How do I check oil level now - or shall I just change the oil and put in required amount.
    The type is 26D.
    Best regards
    Søren
