Took the boat out today for the first run of the season and test out my shoulder after having severely dislocated it in June playing Aussie Rules. All went well, except for a question I have on oil level and pressure.
When I changed the oil in the engine (MP 340 HP), I slightly overfilled it. I was suppose to add 5-1/2 quarts (5.2 litres) as per the forum recommendation and its closer to 5-1/2 litres (5.8 quarts).
I have checked the dip stick and it probably 10mm (3/8")higher than the fill mark.
I figured 300ml was not going to hurt but I noticed that the oil pressure was up there, higher than normal and at skiing speed pegged on the highest blue line on the gauges. When I went faster, the oil pressure actually decreased.
Why is this and should I remove the extra 300ml.
