Hey guys/ ladies
I have posted on here before about my oil pressure issues and had some good advice form all (thanks)
To refresh about my issue, I have good oil pressure on my 2008 MP 340 hp until I load up and ride, then after 10 minutes of riding the pressure at idle drops to 8-10 PSI and the alarm sounds, it slowly pics back up to 10-15 and the alarm stops, when I stop and empty the ballast and idle back to the boat ramp the pressure holds good at about 20 PSI and no alarms sound.
I keep my engine serviced and regularly change the oil myself at about 25 hr intervals with the recommended grade out of the MP manual, I have plumbed in a mechanical gauge and it confirms the dash oil gauge!
My next question about my problem is this.
After finding more posts on this issue I have checked and found air bubbles in the oil on the dip stick, as some one pointed out, this is frothing of the oil caused from over filling the oil, I'm pretty sure I'm filling it up correct however I have now found out on another post pointing out that MP had recalls because the dipstick or dipstick tube was the wrong length.
How do I tell if mine is the correct length?
If this is the problem it would make a lot of sense as the oil is only good until it froths up and I loose pressure?
Any advise would be greatly appreciated
Thanks
Thanks
