Frequent and random power loss for 2007 20V
    Any ideas on what can be causing a random and frequent power loss on my 20V? There is no rhyme or reason (ie. varying speeds, varying loads) when it happens but it is happening very often?
    Could it be something to do with air intake or Fuel filter or injectors?
    The boat basically stalls out (no throttle power) but stays running and then I throttle back and go again.... Sometimes it can go for 4 or 5 minutes and sometimes 5 seconds???
    Any thoughts or tips?
    Check all your wiring harness connections as we'll. I had something similar happen and it ended up being a loose harness connection even though it looked tight. Unplug them and reconnect them to make sure they are all tight. Good luck.
