Last weekend my 2002 Merc MPI overheated because the raw water pump locked up. The over temp alarm sounded and I immediately cut the throttle and killed the motor. After replacing the the raw water pump today, I attempted to start it, but it wouldn't crank over. I then began to pull all the plugs, one of the cylinders drained a small amount of water, obviously the reason it wouldn't crank over. After pulling all the plugs and spraying wd40 in each cylinder the engine cranked over smoothly. I then replaced the plugs and after more than usual cranking the engine ran fine and the temp stayed around a normal 175 at idle and would run cooler at higher RPM.
My question; where did the water in the cyleder come from??? Is my engine in trouble? I checked the oil before running the motor and after reaching running temp, thankfully thers no water in the oil. Thanks in advance for your input!
