Originally posted by tweirich
Ram enough air in there and you'll need an inter-cooler
Getting cool air into the engine housing also requires that you exhaust the hot air. If two blowers are rigged one needs to blow air in, the other needs to suck air out or there needs to be openings to exhaust the air. This would defeat any attempt at boosting the air pressure of the air supplied to the engine. The discharge from the one that blows in would need to be close to the engine.
Then you need to worry about fire safety. If you should ever have an engine fire those blowers would need to stop immediately. Starving the fire of oxygen would buy you a little time. But how much time does it take to grab a preserver and just jump out? Anyway, for safety's sake rethink the plans to try and force more air into the engine compartment full time.
