The other day I took my boat out on a very hot day, 101 degrees to be exact. When I first started the engine it had a slight miss at lower RPM. The boat ran fine at higher RPMs for about 30 minutes. We stopped to float and swim for about 45 minutes. When we went to restart the motor, it would start blowing some black smoke at startup, but when you gave it gas it would die. This continued for 5 or 6 attempts, then we were finally able to keep it running and get it up to 3000 RPM by advancing the throttle very gently and smoothly. After this the boat ran fine. Even turned it off while retrieving the trailer, and it started normally.
Has anyone had anything similar to this and what was the cause????
The boat is a 2000 22i with a Mercruiser 5.7L fuel injected motor.
I've actually got a plan for using two inline, waterproof blowers to basically inject fresh air into the bilge instead of just the one in motor box to suck it out. Anybody could do it. You could probably do it for around $100. I personally just haven't gotten to it yet.
