Since I have had the boat, two seasons now, I have had a chatter or rattle what appears to come from the transmission area. Only while motoring in gear under 1200 rpm or so. Thought is was pretty normal but the more reaserch I do, the more it sounds like I may have to have the damper plate looked at. Any suggestions? Looks like a tough job.
Gear rattle
Coupler bolts are worth a look. Prop nut also. Loose nut on a tapered shaft and the prop could have slide down a little and is now rattling.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
