I have a 2011 rzr with the 343 hp pcm. This is the first tournament boat I have had after boating for about 15years I really only get to you the boat will on summer vacation. We can surf for over an hour or so then the boat will sputter then it will only run at an idle. If we let it sit for 20 mins or so we can run for another 20 to 30 min the it happens again I have changed both fuel filters and the low pressure fuel pump. It is under warranty still but when I only have a limited time to use the boat this is very disappointing. Anyone ever have this happen?
engine sputters then won't run over idle
Originally posted by dom w. forte View PostCheck the raw water filter for debree and also make sure the clear plastic cup is faceing down angle, they can develope an air trap and cause fuel purculation.2013 Z3 - Electric blue and black
