Vapor lock or Sensor issue?
    Well finally got back out to the lake this weekend after being off for a month with a broken arm figured Id update:
    Before I went out we changed the check valve at the tank and ran the blower a lot more. Still no change in vaporlocking. So this winter its gonig to get the water check valve put in it and a secondary fuel pump back by the tank.
      Just got done installing the mercruiser kit. Fixed all my vapor lock issues.
        Thats what I like to hear. Pretty simple fix for a little issue.
          bmxcinci, where did you mount the aux fuel pump?
            almost missed this. been working To much.. lol.. I have a 2000 20i, and mounted it on the starboard side down by an engine mount.. I will try and get a picture up next time I am in the boat. It was a pain to mount, and they only give you about 18 inches of fuel line in the kit.
              that would be helpful. thanks
                Picture of fuel pump
                Finally got a picture of where I mounted the aux fuel pump. No troubles after I installed it.. Started every time.
                  Thats my plan for this winter/spring. Thanks for the pic
