Taps motor
    Taps motor
    My boat is 02 20.1. After buying it I discovered the taps is not working. The previous owner forgot to tell me the dealer unhooked it as he only waterskied. I can't see any wires coming out of the throttle. I also cannot see where the pumps is to check for connection and power. Can someone describe the location of the pump.
    The taps pump (hydraulic version Bennet some years are electric)on a 01 20i is located under the helm, inside the storage area. Its under a carpeted box cover. Some have it in the storage behind the observer seat. If its the hyd there is a possibility its the relay that is dead adn the pump is still good. Just depends on what system you have.
      relay for 2001
