For some reason I have had this problem a couple of times...
When I am filling the boat up while on the water it will not let me put much fuel in, it will just continually spill out over the side. The guy at the dock says it is because it is so hot, however, when I have the boat out of the water on the trailer it fills up fine at a normal gas station. Do I have a venting issue or something?
Also, since my fuel gauge does not work I pulled out the float assembly (it was kind of a lever type) and I confirmed that the sender was working by manually pushing the float up and down and checking the gauge. I am considering replacing it with a WEMA fuel level sensor:
http://www.wemausa.com/tank-sensors/...nk_sensors.htm
thoughts about this?
Also, I have a 2002 Tige 2300V and if I want to order this new sensor I need the know the depth of the tank, does anyone know what depth I should use for this? Just off memory and eyeballing it, I would guess 6 - 10".
Thanks!
Thanks!
