I have a 2003 22VE with a Mercruiser 350. I have used the boat 2 times this summer with no problems. On the third outing, it would bog down over 2800 RPMs after 20-25 seconds under power. I can start from dead stop and accelerate normally and boats performs flawlessly for 20-25 seconds and then it stammers like its needing fuel. My thought is that the fuel water separator fills with fuel at low rpm but uses more than is being replenished, therefore it bogs. When I back down the throttle to 2700RPM the boat does fine without issue. Twin batteries fully charged, 13+v on gauge. After replacing filters, I will check fuel rail pressure.
Starting with least expensive items first, I replaced the fuel water separator. But the in-line fuel filter, part number 35-864572, dealer wants $62!! Guy said it was a special filter and might help avoid vapor lock??
I then tried OReilly, AutoZone and Pepboys for the crossed filters ($8-12). Looks identical to auto in-line for 8.1 Chevy but the fittings are different. The Mercruiser uses metric threads?? Took the auto filters to Lowes for brass barb fittings and they don't fit?? Guy at Oreillys said to use inline with sight glass but I'm afraid the flow rate will be too low, also no way to solid mount. I'd like to make changes easier so that I don't have to take out the floor to change the filter.
Has anyone tried to add a spin-on style 10 micron fuel filter kit from West Marine?? Part number 9399478 "SIERRA 10 Micron Filter Kit for Fuel Injected Engines" The kit is only $42 with filter, replacements are $9. 3/8 in/out fittings should be plenty of flow. Your thoughts?
Are these the only two fuel filters for this motor? I have read that some boats have 3? Thanks for your help!
Clint
Clint
