I bought a 2001 21V Limited Edition and this last year I have been having an issue with the throttle not locking into neutral. I can basically go from forward to reverse with no hesitation. I have taken the whole assembly apart many times and after inspecting each component I have come to find out that the teeth on the throttle shift collar (the chrome piece?- not sure of the technical word) is not locking into the other side of the throttle housed on the boat outer panel. It's as if there is not enough inwards pressure from the screw on the neutral detent button to hold the shift plate firmly enough towards the throttle assembly... if that makes any sense. The neutral detent button is pretty shot but I don't even think this is the only reason this is happening because I also have the set screw underneath that has been able to make up for that, I believe. Anyway, I'm feeling like maybe I'm missing a part in there that possibly wore out and broke over the years. I'm not sure if there is a plastic fitting that goes in between the shift collar and the throttle assembly to help bridge the gap between the teeth or what. Hoping you could shed some light on this and pointing me in the right direction. I realize that Teleflex makes the throttle but I haven't had any luck with them as of yet.. Seems like this throttle is different than any they sell now.. I believe it is the MV-2 but I could be mistaken... It has the TAPS tab built into the throttle. Any new ideas would be great! Sorry for beating this topic to death but I know I'm not the only one having issues becuase I have seen a lot of unanwered threads discussing such...
I found this and it looks like mine... Not sure if it butts up the same though.. Has anyone replaced there throttle completely in a 2001 21V LTD?
http://www.skidim.com/prodinfo.asp?number=108014
Mike
