Wanted: Replacement throttle control system 2007 RZ2
    Hi All
    My throttle control system has problems going into neutral. The little ring that you pull up and down no longer works - you don't need to pull it up in order to move the throttle into gear. My non-tige mechanic thinks this is the reason why my boat has problems starting. The starter motor will run but the engine doesn't turn over. So he thinks I need to replace my entire throttle system. Anyone has a spare/replacement?
    Regards
