Hey guys, can anyone give a little advice or how to on the packing of the prop shaft? I had a bent prop on my 97 Tige pre 2050. I noticed water coming in the engine compartment when the boat sat anchored. and when I was driving no water would come in what so ever. It was taking on an inch and a half of water within 30 minutes. So I looked at it no leaks, noticed water was leaking out of the shaft from the prop. So took the prop off ordered a four blad which will be here tomorrow. Figured leak is coming from the packing being bad. So I guess my question is how to replace and put in new packing? Any links or videos would be helpful to. Thank you all for your time.
Any advice about the packing on prop?
I ended up replacing mine with a new PSS.
http://www.tigeowners.com/forum/show...&highlight=pss
http://www.tigeowners.com/forum/show...ghlight=skidim
Here is a thread on replacing the packing.
http://www.tigeowners.com/forum/show...&highlight=pssLast edited by TeamAllen; 08-11-2011, 06:29 AM.Mike Allen, Tigé owner since 1997
