Hello, new to the board. The boat is a 2008 RZ4. When started and in neutral, the boat has a loud noticeable squeal. Seems to be louder on the driver side and can't tell if it is coming from underneath or the engine compartment. The boat also has a vibration when starting to pull someone out of the hole wakeboarding or water skiing. I was thinking possibly a belt for the squeak and maybe a chipped prop for the vibration.... Any help would be greatly appreciated!
Thank you
Thank you
