2000 20CI. Yesterday PM. I wanted to change the Taps setting. The switch only moved the Taps up, not down. When ever I change the setting the volt meter drops while I am pushing the switch. What do I check first? Please reply. I want to use my boat next weekend
Taps starting to give a problem
Check the fluid level in the tank under the pump. This is in the back locker on the drivers side on a RZ2. I had this same problem last year after the fluid "burped" some air that was in the line and the level dropped. Also check that the hose to the taps isn't leaking (or the connection to the fluid tank).
Yup its the lack of ATF in the Tige pump that is causing the problem. Just unscrew the cover and there is a inlet at the bottom right hand side of the TAPS. Just pull out the plug and fill it up with a turkey baster. Let me know if you need any pictures on how to do this. Happy to post up the pictures if you would like
