I called the tige dealer and they also said to check all grounds. They all looked good. I replaced the starter relay($12bucks at napa) and the boat is starting every time so far....I am hoping it was just a bad relay that would work intermitently. Back to the resevoir it will go this weekend. If I do get the issue again I will make sure the solenoid has power....if so then the next thing would be to replace the starter/solenoid. Hopefully she will be a good girl for now on
