Paddle Wheel location on 2002 21V riders edition
    Does anyone know where tige loaded the perfect pass paddle wheel on the 2002 21V, or have a picture of what it looks like. My digital speedometer on the perfect pass reads 0 and I need to test it but I have to find it first.
    Thanks
    Mine is under the transmission to the port side. That is where PP instruction pictures had it located and I installed my own. You should be able to see it with the boat on the trailer.
      Mine is at that location as well.
      2001 21V Riders Edition - 08 F-150 King Ranch
        Opened up the engine compartment last night, and sure enough it is there.... sitting over the very back corner of a trailer bunk...DOH!. I was able to remove it from the inside and sure enough it is broken. I just bought this boat and I don't know the history on the trailer. It looks like I can reposition the winch post back a few inches to clear it. I just hope that doesn't unbalance the boat... Now if I can figure out how to order a replacement...
          Should be made by Arimar and readily available. Might even be able to order a rebuild kit to replace the wheel depending on what is wrong.
