I have a 2003 22v riders edition. When loaded down it miss fires a couple times while in a hard turn. I have also notice my gas consumption is up and can smell gas out of exhaust while wake surfing. I have replaced plugs and rotor but cap looked fine. Any ideas? 350 mpi mag tow sport
Motor miss firing while turning
There are two sensors in the manifold that cause similar issues. The ECT measures cooling water temp and will overfuel an engine if it's reading false cold. The manifold air temp sensor will also contribute to fuel mixture problems if it too is out of whack.Fixing everyone elses boat just so I can use mine...
Originally posted by boatwakes View PostThere are two sensors in the manifold that cause similar issues. The ECT measures cooling water temp and will overfuel an engine if it's reading false cold. The manifold air temp sensor will also contribute to fuel mixture problems if it too is out of whack.
Is this something that has cropped up since the prob was reworked?
3K ballast and 12 peeps sounds like it might be time to stop the power-turns or get a custom prop.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostIs this something that has cropped up since the prob was reworked?
Originally posted by goose69 View PostWas happening before prop just getting worse on fuel consumption. Had the prop done at a local shop they screwed it up gave me my $200 back then sent to acme and they did an awesome job for $125 plus shipping. I though it was a rotor cap problem or wires but would that explain the gas smell out the exhaust. Someone mentioned waters sensors but I only have one? Only thing else I did was replace both batteries with hummer batteries (1900 cranking amps) which improved the stereo.
Most engine misses occur under load. I dont see turning being more load then the load placed on the engine during hole-shot.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI just dont see why the engine would want to misfire during a turn. The engine doesnt know its turning, no like there are any yaw sensors in there.
