2007 22ve hit a wake hear a beep and boat goes to idle
    anyone have any idea on how to fix this problem. I have a 2007 22ve less then 100 hours on it. Last 5 times I have taken it out. u will be cruising at 40 mph hit a wake and the boat beeps then goes to idle ded stop in the water. Bring it to the dealer says no codes and nothing wrong with boat. Any ideas would help. even does it at low speeds when someone is wake boarding hit a wake boat beeps and stops.
    Do you have the EIDB dual battery option? If so, check for loose connections on the batteries and if they still have wingnuts, swap them over to ny-lock hex nuts. Also check for a loose connection on the Knock Sensors. Last would be the oil level. There was a recall about the dipstick tub being the incorrect length. It would result in an overfilled crankcase. This caused the oil to foam and possible show a false oil pressure. That engine has two oil sending units: large one runs the gauge and the small one goes to the ECM for the sounder. ECM could be seeing low oil pressure and putting the engine into protect mode. May also be loose connection or loose throttle position sensor on the back of the throttle assembly.
      Knock sensor is loose
