need a little help here guys...
Chp is getting me a new prop and when I was under the boat confirming the existing prop I noticed a scuff on the hull directly under my prop.
I bought the boat last fall and did a thorough inspection of it, as the chip is right above the prop I may have missed it if it was there.
What would this be from? I am packing about 2700 lbs of ballast and 3 people and two kids generally for weight...there is no way the prop could be hitting the hull is there?
Only other things I can think of is that maybe the previous owner tried to put too large a prop on or I wrapped something around mine and it hit the hull???![Confused](https://www.tigeowners.com/core/images/smilies/confused.gif)
any thoughts??
any thoughts??
