Starter Fuse Blown 2020 RZX 400 Raptor
    Trying to avoid the dealership, too busy and a few hours away. I am at the point of not caring who's fault it is. About a month ago, the plug from the middle of the boat that is next to the central ballast pumps was not put back. You access that area by lifting the middle floorboard and removing the circular panel. The boat was in the water two times, bilge running the whole time. Initially thought dealer forgot plug underneath and it was left over water from when they lake tested. Turns out, water was coming through that hole and flooding the ballast pump area. The boat struggled to hit 10 mph. Hoping this is not connected to an incident. A few weeks later the starter fuse blew. When I turn the key, no sound at all, the engine does not turn over. Everything else works fine, beeping, the screen lights up and stereo. Was in neutral every time. Decided to replace batteries. After going out about 5 times it blew again. Checked the panel in front of the steering wheel, everything on that corner panel seemed tight, I can check again. I have been searching for a while but not many post align exactly with my issue. If anyone can rule out a new starter that would be awesome. Any help is much appreciated. 400 Raptor Engine roughly 280 hours.
