Noticed this weekend after running my boat for a couple of days straight that I can hear a clunking noise in the v drive/trans area. It only does in when you first put it in gear and idling. As soon as you give it gas it clears up. Any ideas what this could be?
clunk in v drive just when idling in gear
Possible flex-plate coupler between engine and trans.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by oleblue View PostWell I think I found my vibration. The prop nut backed off and was resting on the cotter key. I got a new nut, I take it there is no washer that is supposed to go on. Is there a torque spec for it?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by dougpaper View Postmy 2005 22v does the same, noticable but not distracting and it goes away completely at anything above idle. I think it is just the nature of the v drives at idle
Did you guys see the results above? It was the shaft retaining nut to the coupler. Check all hardware in the coupler area is tight because IT IS NOT THE NATURE OF V-DRIVES to make this noise. They should be smooth and quiet. A rattle at idle may also indicate the engine is not running properly. When the engine doesn't run right (usually carbureted but dirty fuel injectors, bad spark plugs etc...) it loads and intermittently unloads the drive plate while in gear at idle but goes away above idle speeds or when not in gear. Inspect all hardware carefully, especially the coupler bolts and shaft retaining nut, they could shear and leave you stranded if they're loose. Again, the rattle should never be there so determine what it is and repair.Fixing everyone elses boat just so I can use mine...
