2007 Tige 22I Taps issue
    Looking for some input on an issue I am having with the Taps system. When placed in position 1 and traveling at speed (25-35 MPH) I notice the TAPS gauge will move from position 1 to position 3. Once I stop, I can move the plate back to position 1. Has anyone experienced this and if so, what was the solution? The ram is not leaking fluid. Could the one-way valve in the pump be going bad and allowing the fluid to travel back into the pump while under load? (Hopefully I have a decent understanding of how the system works). Any help would be greatly appreciated.
