Circuit Breaker
    Circuit Breaker
    I have a 2007 24VE with the Marine Power engine. There is no power to the gauges or ignition. All other works, stereo, blower, bilge pump, lights etc....new batteries...
    The red 50 amp circuit breaker on top of the engine seems to be tripped. When I try to push on the button it will not move at all, stuck in the out position...
    Any ideas?
    Thanks Rick
    Sent from my SM-S918U using Tapatalk
    Do you have a volt/ohm meter? If so, measure for voltage on both threaded posts.
      If like my 2003 22v, there are various inline fuses up under the dash. And a small fuse block under the dash.
        Mike, I do have a meter and I'll check that and get back with you!
        Thanks Rick
          Mike, I am getting no voltage on either terminal on the circuit breaker....
          T
          Rick
            This indicates the issue is upstream of that breaker.
            Had any work been done on the boat just prior to discovering this gauge/IGN issue? This time of year I see a lot of boats getting batteries reinstalled or new ones swapped in and its very common for a rogue battery cable to get left off.
              Yes on the work! I just had my audio guy replace the stereo and both batteries!! I will look for that rogue wire because I had no issues prior to this one!!
              thanks. Rick
                Is that a direct feed from the battery or does it come from somwherr/something else??
