HELP with PERFECT PASS..
    OK,, I need help, I have a 1995 Tige 2000SLM, it has EFI 350 and I just got my stargazer kit, they said the install was going to be straight forward, but here is my problem, Look at the pictures and you can see that it does not have the normal setup like a carb. If I remove the red ball joint the cable is not long enough to reach the throttle butterfly, also the if I hook it up like the directions say were the servos and the cable connect together how does this work if my throttle cable is a pull cable not a push cable. I hope this not to confusing please look at the pictures and see what I am talking about. If someone could provide a number so I can talk through this would be great.
    Thanks.
    No help needed,, Got it!
      I am a new member here. But pls visit our homepage URL through my Signature and URL Link....
      __________________________________________________ __________________
      RS appliques
      RS wholesale
      RS t-shirt
