Taps 1 gauge sending unit
    Finally got the big stuff completed...thanks to tigeowners (shout out to boatwakes). Now for the details. My TAPS gauge has not worked in years. Bought a new one some time ago and no go. Called Bennett and they did not know the part number of the ram position sending unit that was used back in 2000. Did the search and came up blank. Does anyone know the sending unit part number from Bennett? Surely someone has replaced theirs after all these years. Thanks
    OK, learned additional info for you TAPS 1 crowd. The Bennett 198 TAPS kit was originally used on our boats. The new number for the sensor/hinge that controls the gauge is ATPSEN1.225SD according to Bennett. This is for both sides and we only use one. If this works, I will have an extra available. Bennett customer service assures me this will work correctly for our application. Wish me luck.
      That's the same info bennett gave me when emailing them.
      How did the install go? Any tips? I'm about to purchase the two units.
      Are you interested in selling me your spare?
      I came across this video... This pretty close to how things went for you on the install? (of course we're replacing the opposite end of the drive unit)
      ​​​​​​​https://youtu.be/lItp77P34mw?si=rw92IDz8h1-siaSk
      For future people searching for part numbers ect.
      The following is the proper part number for the replacement UPPER HINGE SENSOR COIL:
      BENNETT MARINE INC PART # YAMAHA P# UNIT OF MEASURE DESCRIPTION RETAIL (USD)
      ATPSEN1.225SD 6BT- 5010123 -00 EA Catalog # for ATP HYD 1.225 SD PAIR $98.10
      This kit will provide you with two (2) UPPER HINGE SENSOR COILS, so you will have a spare for the future! You can SPECIAL ORDER (read as NON-STOCK item, MANUFACTURED WHEN ORDERED ONLY) them from any of your local marine dealers, catalog, Internet retailers (“WHERE TO BUY” webpage https://bennetttrimtabs.com/find-a-dealer/) &/or your area YAMAHA OUTBOARD DEALER using the supplied YAMAHA PART NUMBER (YAMAHA OUTBOARD DEALER FINDER link; https://yamahaoutboards.com/en-us/find-a-dealer) (we are NOT setup for direct sales of our products).
