Taps 3 surf plates
    Taps 3 surf plates
    My buddy bought a 2019 RZX3 today and we could not get a wave to form. Put it back on the trailer and in service mode the plate actuators will extend 2.25” as they should. But if he holds the plate with his hand to simulate the water against it when they deploy at 7.5 mph they only extend around 1.5”. So that explains part of it, needs new actuators. But when we were looking at it from behind the port plate is about 1.5” higher, or closer to the platform than the starboard plate. The goofy wave is by far worse than the regular wave so between the actuators not deploying full amount and then that port plate being higher it does not dip in the water as deep. Can someone measure their boat and tell me what the factory distance from the inside top edge of the plate to the underside of the platform is please?
    Thank you!
    71 Cut Supreme, 70 3 Door Suburban, 08 Tahoe LTZ, 12 F21 Surf Machine!
    http://i260.photobucket.com/albums/ii11/onetogofast/IMG_4360.jpg
    These are the original design plates. Not the GSA plates.
