Marinepower G Force Fuel Pump
    I need to replace my GForce fuel pump. Marine Power part numbers are 438716 for the just pump and 438704 for the whole assembly.
    Local dealers have no stock, Marine Power won't answer my emails/calls, I can't find stock online anywhere such as, Marine Engine Depot - as mentioned in older threads.
    Does anybody know of a cross reference for an equivalent pump? Or have any recommendations for replacing the whole high pressure pump assembly with something that actually has parts available? Engine is a Vortec 5.7L
    I really appreciate any help.
    I believe it's from a diesel truck. PFP58054
      I just recently purchased the Delphi fuel pump CHFP964..and it fit and works...but when you remove the metal hood to get to the actual pump cartridge, there's a black triangle plastic piece with a rubber triangle shaped O-ring...Dont lose that and make sure it stays in place when you put it all back together otherwise you will have 91 octane pumping into your bilge...and you will be looking for that plastic piece in the bilge after the pump spits it out with the fuel....
        [mention]duffymahoney [/mention] You just saved my season! I was able to cross reference from that to a slew of other suppliers and managed to find one in stock nearby.
        I cannot thank you enough man!
          You are welcome
            What were your symptoms? I am chasing a fuel bleed off issue and trying eliminate the pump as the culprit. I have the whole boat torn apart lol.
