Good morning. I have a 2007 Tige 22i with a 340HP motor. On first start-up, the boat runs fine. Drive for a while, shut off for more than a few minutes, and the boat won't start. The fuel pump takes a while to prime but even after priming and then shutting off, the boat will not start. It is almost like it is vapor-locking. Any ideas? I am going to replace the fuel filter but was wondering if there is anything else I should be looking at.
2007 22i not starting after running for a while
Originally posted by kevin 2765 View PostGood morning. I have a 2007 Tige 22i with a 340HP motor. On first start-up, the boat runs fine. Drive for a while, shut off for more than a few minutes, and the boat won't start. The fuel pump takes a while to prime but even after priming and then shutting off, the boat will not start. It is almost like it is vapor-locking. Any ideas? I am going to replace the fuel filter but was wondering if there is anything else I should be looking at.
