I’ve had intermittent issues with my boat since I got it 3 years ago that seemed like they could be fuel related.
I just noticed that when I click the key on but don’t start the motor , the fuel pressure comes up to 65 lbs, the pump stops whirring and then the pressure leaks down to 0 lbs over about 10 seconds.
I’m thinking this is an issue so I am trying to figure out what is causing the leak down.
Can anyone confirm this is the fuel pressure regulator?
I replaced it with the same part that was already there but it came up as a fuel filter from NAPA however I see a part from GM. That looks almost identical that is called out as a fuel pressure regulator.
Any insight out there would be greatly appreciated
Thanks
Thanks
